TwinTurbo.NET: Nissan 300ZX forum - Is any part of the reroute under engine vacuum?
Subject Is any part of the reroute under engine vacuum?
Posted by AzHeat on February 16, 2007 at 11:19 AM
  This message has been viewed 151 times.
In Reply To His engine was out of the car and being worked on posted by Woody75 (Denver) on February 16, 2007 at 11:09 AM
Message I ask this because, crank case pressure goes up a lot under boost. I was watching an old MKIII Supra turbo car on the dyno on time that had one of those K&N filter for valve cover breathers. When the boost came on, a lot of crank case vapor dumped out like fog.
A lot of domestic racer use an external vacuum pump to ventilate the crank case because there is pumping loses from the pressure on the back side of the piston. Also oil will less likely pool in the valve covers if the crank case is under vacuum. I am going to hook mine up so they are always under vacuum like the stock set up. The only difference is it will be filtered more through the catch can.
